BMW R51/3 1952 - letters stamped on the thooted clutch ring
Begonnen von Michael Steinmann, 23 Juli 2020, 14:08:37
Michael Steinmann
Hello all.
I have Z and T stamped on this ring, and am intending to assemble the clutch.
I wonder why are they there for? AFAIK they can't be seen from the inspection window of the engine cast.
Thank you kindly in advance -
Michael
they can´t be seen?#Normally is "Z" for the ignitionspoint at idle (or lower)....and "T" must be "OT" for the highest point of the piston (oberer Totpunkt)
Michael Steinmann
Thank you for your reply.
Well, I assume they can't be seen, probably I'm wrong here.
How do I use them? Is there an article on the web that explains how to calibrate the engine with these marks? Couldn't find it in the workshop manual.
it is useful when you measure the ignition and the valves
wimitz
Hi Michael,
you will find most needed explanations here: [size=78%] [/size] .
Martin
Michael Steinmann
